KDE shutdown [solved]
Help on MX KDE Re-spins
Mauser
Post by Mauser » Fri Jul 21, 2017 1:40 pm
I am using KDE and when I click Leave none of the other selections in the application menu respond. I usually get a box with options but not anymore. Shut down, Restart, or anything else.
I am command line illiterate. :confused:
chrispop99
Re: KDE shutdown
Post by chrispop99 » Fri Jul 21, 2017 1:52 pm
Have a look at System Settings>Startup and Shutdown>Session Management, and see if there is a tick next to 'Offer Shutdown Options'.
Test machines:
Mauser
Re: KDE shutdown
Post by Mauser » Fri Jul 21, 2017 1:57 pm
chrispop99 wrote:Have a look at System Settings>Startup and Shutdown>Session Management, and see if there is a tick next to 'Offer Shutdown Options'.
Thanks. Too late. I had it with KDE. I did a force shutdown hitting the power button. When I booted up the shutdown would work but it messed up all the themeing. I am back on Xfce for good because KDE has been a headache for me. Thanks anyway.
chrispop99
Re: KDE shutdown [solved]
Post by chrispop99 » Fri Jul 21, 2017 2:03 pm
KDE requires more time to learn how to set it up, that's for sure!
Test machines:
Post by Stevo » Fri Jul 21, 2017 2:23 pm
Was this with the KDE respin, or did you add it yourself?
Mauser
Post by Mauser » Fri Jul 21, 2017 7:01 pm
chrispop99 wrote:KDE requires more time to learn how to set it up, that's for sure!
Yes, it does. It's a real pain to set up. Poor documentation as well.
Mauser
Post by Mauser » Fri Jul 21, 2017 7:07 pm
Stevo wrote:Was this with the KDE respin, or did you add it yourself?
No, it's the stock KDE that comes with MX that I was setting it up the way I want through the use of the KDE settings. I wouldn't call it a respin. With the very poor documentation that KDE has it's trail and error and sometimes it goes right off a cliff.
Post by richb » Fri Jul 21, 2017 7:28 pm
I found it quite easy to configure. But I have a lot of experience with KDE. (had that is).
Rich
SSD Production: MX 18.1
Post by Stevo » Fri Jul 21, 2017 10:47 pm
I'm still not clear what you mean. KDE doesn't officially come with MX--did you install it via the package installer, or use the unofficial KDE-added respin that I did?
Mauser
#10
Post by Mauser » Sat Jul 22, 2017 8:07 am
richb wrote:I found it quite easy to configure. But I have a lot of experience with KDE. (had that is).
In some cases it's easy to configure but in other cases it's not. I would imagine the experience you have with KDE the easier it would be. The problem is when you don't have much experience with KDE it's easy to go over a cliff with it depending on what changes you are looking to make and how far you go off the beaten path with it. The poor documentation compounds that problem. I don't find that problem with Xfce as their documentation is clear and concise.
Return to “MX KDE”
