MEPIS 12/MX 14 Community Repository: The SMPlayer Thread
News about updates on package status for CR packages compiled for MEPIS 12.0
Post by Stevo » Mon Jul 22, 2013 11:55 pm
This is the first updated SMPlayer build for the M12 community repo. SMPlayer is a great QT4 GUI for the mplayer or mplayer2 media engine:
http://smplayer.sourceforge.net/
0.8.5+git5552 (pulled from the SMPlayer source code git repository) is now in the test community repository. Ricardo has being fixing a constantly changing Youtube API, he thinks now with 5552 it can update itself to fix the issue. This will also get rid of that updated nag :crossfingers: :)
Postby rvm » Wed Jun 19, 2013 3:00 am
It seems youtube did it again and smplayer fails to play many youtube videos (mostly music videos).
I'll try to fix it as soon as possible.
rvm
Site Admin
Top
Re: Youtube not working with some videos
Postby rvm » Sat Jun 22, 2013 11:57 pm
Hopefully the problem is fixed in svn r5473.
rvm
Site Admin
Top
Postby rvm » Fri Jun 28, 2013 3:05 am
Youtube did it again and music videos can't be played.
Edit: fixed in svn r5487
rvm
Site Admin
Top
Postby rvm » Sat Jul 06, 2013 3:34 am
More details about the problem with youtube:
http://blog.smplayer.info/trouble-with-youtube-videos/
rvm
Site Admin
Top
Postby rvm » Wed Jul 10, 2013 12:26 am
Broken again.
Youtube is using now a 83 length signature.
rvm
Site Admin
Top
Postby rvm » Wed Jul 10, 2013 11:25 am
Fixed in svn r5501.
rvm
Site Admin
Top
Postby rvm » Thu Jul 11, 2013 10:17 pm
Another change in youtube... Fixed in svn r5504.
rvm
Site Admin
Top
Postby rvm » Wed Jul 17, 2013 9:43 am
Broken again.
Now they are using a 92 length signature.
rvm
Site Admin
Top
Postby rvm » Sun Jul 21, 2013 10:50 am
Experimental: since r5552 smplayer can update the code that decodes the youtube signatures, so it won't be needed to update smplayer every time youtube makes a change.
Re: MEPIS 12 Community Repository: The SMPlayer Thread
Post by Stevo » Thu Aug 22, 2013 12:14 am
Update: 0.8.6 is now in the test repository, along with an update to smplayer-skins and smtube-1.8. I tried a problem "Vevo" Youtube music video, SMTube informed me there was a problem and would I like to download an internal update to fix this. After the update, I was able to view and download the video (Anna Kendrick's "Cups"). There are also a few more bugfixes.
Post by Stevo » Fri Apr 04, 2014 9:18 am
SMPlayer has changed its versioning; from now on it's year.month, so this new update is 14.3.0. We now have it in the test CR. Changes include:
SMPlayer 14.3 released
Postby rvm » Tue Apr 01, 2014 10:43 pm
Previous version was 0.8.6, this new release is 14.3... What happened? Now the version is just the year and month of the release.
Version 14.3
The control for fullscreen mode has been rewritten and improved. Now it is displayed over the video.
(Windows) New option in Preferences -> Subtitles to enable or disable the use of the Windows font directory. Disabling this option prevents the annoying font scanning.
Some presets have been added to the audio equalizer.
(Experimental) Possibility to play (non-protected) blu-ray discs.
Better support for multimedia keys. This can help control SMPlayer with a remote control.
New option in the playlist preferences for adding automatically other files in the folder to the playlist.
The option "Move the window when the video area is dragged" has been fixed.
(Windows) Now it's possible to open Windows shortcuts (symlinks).
Better support for Youtube.
(Windows) Better screensaver disabling.
Many bugfixes.
Possibility to compile with Qt 5.
Post by Stevo » Fri Dec 05, 2014 4:00 pm
We have a new version of SMPlayer in the test repository, 14.9.0+svn6511, which adds experimental support for mpv as the playback engine. The developer did a lot of work, almost seven thousand lines of code, to get most of it working. Here's a link to the developer's blog where he notes what's not working, advantages of mpv as the engine, and new features thanks to mpv. (some need mpv >= 0.7) http://blog.smplayer.info/smplayer-with ... available/
kmathern
Post by kmathern » Fri Dec 05, 2014 6:43 pm
Did something go wrong with the upload?
Err http://main.mepis-deb.org/mepiscr/testrepo/ mepis12cr/test smplayer i386 14.9.0+svn6511-1mcr120+1
  404  Not Found
Failed to fetch http://main.mepis-deb.org/mepiscr/testrepo/pool/test/s/smplayer/smplayer_14.9.0+svn6511-1mcr120+1_i386.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
And it's not here: http://main.mepis-deb.org/mepiscr/testr ... /smplayer/
Though apt-cache policy says it is (or should be)
$ apt-cache policy smplayer
smplayer:
  Installed: 14.9.0-1mcr120+1
  Candidate: 14.9.0+svn6511-1mcr120+1
  Version table:
     14.9.0+svn6511-1mcr120+1 0
        500 http://main.mepis-deb.org/mepiscr/testrepo/ mepis12cr/test i386 Packages
 *** 14.9.0-1mcr120+1 0
        500 http://main.mepis-deb.org/mepiscr/repo/ mepis12cr/main i386 Packages
        100 /var/lib/dpkg/status
     0.8.0-1+deb7u1 0
        500 http://ftp.us.debian.org/debian/ wheezy/main i386 Packages
Post by Stevo » Fri Dec 05, 2014 7:15 pm
That's weird, we'd better ask Tim. The package upload is also here: https://copy.com/izPsm1d1XTiGvpwr
Post by timkb4cq » Fri Dec 05, 2014 9:23 pm
I don't know what happened. I uploaded the package again just now and it's now installable.
Post by Stevo » Fri Dec 05, 2014 10:09 pm
Hmmm.....
lucky9
Post by lucky9 » Fri Dec 05, 2014 10:27 pm
Obviously Stevo has inside information. :happy:
@ Stevo: what is your Avatar now?
--Mark Twain
#10
Post by Stevo » Sat Dec 06, 2014 1:35 am
The avatar is a clip from a bad '50s sci-fi movie called "The Brain from Planet Arous".
There's a lot of other animated gifs from it here: https://www.tumblr.com/search/The+Brain ... anet+Arous
Too bad avatars are limited to 62 Kb, I could mine this WTF video for many more:
https://www.youtube.com/watch?v=o0u4M6vppCI#t=188
Return to “Package Status - 12.0 Beta”
