MX-14.1.1 "Symbiosis" bugfix/enhancements release
Post by anticapitalista » Wed Jun 18, 2014 5:15 am
MX-14.1.1 "Symbiosis" bugfix and enhancements release available
Almost 3 months on from the release of MX-14, we now make available upgraded versions (pae and non-pae). This version has fixed some bugs found in MX-14 and Debian upstream, and includes updated packages and some new features.
Iceweasel replaces qupzilla
LibreOffice updated to 4.2.4 version
MX-packageinstaller replaces metapackage installer
Easy frugal and persistence set up.
New default theme and icon set ("Zukitwo-Dark" and "GNOME-Brave").
Available here:
https://sourceforge.net/projects/antix- ... l/MX-14.1/
Enjoy!
Reason: Mod edited to provide requested info
Eadwine Rose
Re: MX-14.1.1 "Symbiosis" bugfix/enhancements release
Post by Eadwine Rose » Wed Jun 18, 2014 5:17 am
Thank you so much for all the work!!
It boots right off, no issues, I installed the nvidia driver on the livecd without a hitch, next is an install :smile:
MX-18.3_x64 May 26 2019 * 4.19.0-5-amd64 ext4 Xfce 4.12.3 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 390.116 * 2x16Gb DDR4 2666 Kingston HyperX Predator
Samsung 860EVO * Samsung S24D330 & P2250 * HP Envy5030
Post by Jerry3904 » Wed Jun 18, 2014 5:20 am
Torrents are now on the MX Download page:
http://www.mepiscommunity.org/download-links
Other sources will be listed there as they become available.
fu-sen
Post by fu-sen » Wed Jun 18, 2014 7:20 am
Congratulations and Thanks! :happy:
:party2:
I look forward to a reaction of MX-14.1.1 which strengthened Japanese.
Post by Jerry3904 » Wed Jun 18, 2014 7:28 am
That looks great!
Your desktop image makes me think: over the next cycle, we need to begin to translate at least some of the Documentation, beginning with the QuickStart. I will pursue that once things settle down a bit.
Post by Adrian » Wed Jun 18, 2014 7:58 am
Just a clarification, if you installed and use MX-14 you don't need to re-install. These are improvements that matter to LiveCD use, and obviously if you want Iceweasel instead of Qupzilla you can do the change yourself.
joany
Post by joany » Wed Jun 18, 2014 8:15 am
New default theme and icon set.
Question: On existing installations, is it advisable to remove metapackage installer and add MX-packageinstaller?
2.4GHz AMD Athlon 4600+
Post by asqwerth » Wed Jun 18, 2014 8:19 am
Adrian wrote:Just a clarification, if you installed and use MX-14 you don't need to re-install. These are improvements that matter to LiveCD use, and obviously if you want Iceweasel instead of Qupzilla you can do the change yourself.
.... [snip]
MX-packageinstaller replaces metapackage installer ....
Is MX-packageinstaller a different program (under a different name) from metapackage installer, or will the normal updates of version 14.0 pull in this new replacement package? [similar/related question to joany's above; was about to post my question when I saw hers]
Also, what is the new default theme and icon set?
Post by Jerry3904 » Wed Jun 18, 2014 8:23 am
Both work, though you only need one. The new MX Package Installer has updated content and code, and will be maintained from here on out for MX Linux.
Existing users will need to install MX Package Installer, MX Boot Repair and MX Switch User if they want them. The new theme is "Zukitwo-Dark" and the icon set is "GNOME-Brave"
#10
Post by dolphin_oracle » Wed Jun 18, 2014 8:25 am
mx-packageinstaller should be available in the default repos for installation. there are a couple of differences in the app selection (Browser for instance contains options for qupzilla), and since adrian did the coding, it will be much more likely to be updated than the older metapackage-installer.
lenovo ThinkPad T530 - MX-18.3
lenovo s21e - antiX-19 beta 2 (live-USB)
Return to “Older Versions”
