MX-14.1.1 "Symbiosis" bugfix/enhancements release
chrispop99
Re: MX-14.1.1 "Symbiosis" bugfix/enhancements release
#61
Post by chrispop99 » Fri Jun 20, 2014 11:00 am
Stevo wrote:If the testing repo is disabled in the shipping MX 14.1.1, we should make a note of that.
Test repo is not enabled by default in either MX-14 or MX-14.1.1; they are both the same
Test machines:
Eadwine Rose
#62
Post by Eadwine Rose » Fri Jun 20, 2014 11:28 am
Good.. as it should be IMHO. People who are new to linux (which is what is pouring over from win98 and such) shouldn't be worried with the testing bits (and have higher chances of breaking things).
MX-18.3_x64 May 26 2019 * 4.19.0-5-amd64 ext4 Xfce 4.12.3 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 390.116 * 2x16Gb DDR4 2666 Kingston HyperX Predator
Samsung 860EVO * Samsung S24D330 & P2250 * HP Envy5030
lucky9
#63
Post by lucky9 » Fri Jun 20, 2014 12:56 pm
To 'see' something in the test CR you need to reset Preferences to 'prefer mepis' then Reload. (That is assuming you enabled the test repos first.)
--Mark Twain
kmathern
#64
Post by kmathern » Fri Jun 20, 2014 1:14 pm
lucky9 wrote:To 'see' something in the test CR you need to reset Preferences to 'prefer mepis' then Reload. (That is assuming you enabled the test repos first.)
You don't need to do that in MX14 (you do in Mepis 11 & Mepis 12 because of the way Warren setup their apt pinning & preferences)
All you need to do in MX14 is enable the test CR (and Reload).
I have the Distribution preference set at the default of "Always prefer the highest version".
And here's what it shows for lazarus:
The '...mcr12' version packages are the ones Stevo built that are in the test CR.
Gordon Cooper
#65
Post by Gordon Cooper » Fri Jun 20, 2014 5:31 pm
Stevo wrote:
Lazarus 1.2.2 is in the MEPIS 12 testing CR. Make sure that it's enabled under Repositories in Synaptic.
Sorry Steve, I forgot to enable the testing Repo. My error.
#66
Post by Stevo » Fri Jun 20, 2014 10:56 pm
No big deal. Have you had a chance to work with the new version yet? If it seems OK, we can move it to the main CR.
Gordon Cooper
#67
Post by Gordon Cooper » Sun Jun 22, 2014 1:24 am
Stevo wrote:No big deal. Have you had a chance to work with the new version yet? If it seems OK, we can move it to the main CR.
Downloaded and had a brief play, it looks good. However, I'm a bit disorganised for a few days, changing over a fibre optic feed, have had to move desk, computers and radio gear while we drill a hole through 8 inches of concrete, then everything has to move back again. A
great chance to tidy up the wiring. Most of the gear here runs off solar powered storage batteries and cabling has grown into a muddle..
Will speak up about a move to the main when sanity/stability is restored.
#68
Post by Jerry3904 » Sun Jun 22, 2014 9:08 am
Utopia wrote:
And a nice comment by linuxscreenshots:
Very clean interface. I'm a fan of the side dock position
Henry
They have corrected the caption below now (I posted a comment)
Gordon Cooper
#69
Post by Gordon Cooper » Mon Jun 23, 2014 4:18 am
Stevo. Believe we should leave it in CR at present. The compiler is compiaining about missing
files and, 1.2.2 may already be out of date. 1.2.4 is current on SourceForge and work is continuing
on 1.3. Trying to determine when (or if) it becomes final. It may be reasonable to settle on 1.2.2
but I'm not sure.
Gordon Cooper
#70
Post by Gordon Cooper » Fri Jun 27, 2014 1:13 am
Back in business again Stevo, optical communications feed duly installed, just have to make peace with the neighbours, part of their front yard
had to be dug up to locate the ducting - and in midwinter here there's more than a bit of mud.
Maybe better leave Lazarus 1.2.2 in the testing repo a bit longer. Am trying to resolve a missing file problem, it's certainly there in the download but the compiler cannot find it. This did not happen with the earlier version so am looking for the error.
Gordon
Return to “Older Versions”
