Calling for MX-18 conkies
Any MX member can start threads and post in this section. Feel free to express your views, make requests, offer support, give ideas - basically anything to do with MX art. Art usually is an "in the eye of the beholder" thing - so please respect everyone's right to their own personal taste!
Re: Calling for MX-18 conkies
#21
Post by Jerry3904 » Fri Nov 16, 2018 7:55 am
More of the same...
1) That toggle was placed in Favorites with MX-17. If you upgraded from an earlier version and kept home, then you won't see it there.
2) If you type the first couple of letters of the word "conky" into the top search area of Whisker menu, the toggle appears at the top of the list.
#22
Post by asqwerth » Fri Nov 16, 2018 1:58 pm
BBQ-Digital
- modified from a conky from a LinuxBBQ release with XFCE (2014-2015)
- media player script is the same one in my earlier post
#23
Post by Jerry3904 » Fri Nov 16, 2018 2:14 pm
(I love BF, have seen him many times in concert)
That's nice. I wonder if we could also separate out the Clementine what's playing, b/c I have a nice little DeaDBeeF one.
#24
Post by asqwerth » Fri Nov 16, 2018 2:30 pm
Managed to see Bela Fleck and the Flecktones live once. Amazing.
...wonder if we could also separate out the Clementine what's playing, b/c I have a nice little DeaDBeeF one.
You mean a deadbeef script for conky?
Maybe you need one of those "if-then-else" or "if-running" type of lines to choose between different media players. You would need someone better at programming to do it, though. Maybe fehlix?
#25
Post by Jerry3904 » Fri Nov 16, 2018 3:41 pm
Neither of those conkies recognizes that I have Clementine playing (Brad Mehldau Trio, Ode, from my cache in Dropbox).
#26
Post by asqwerth » Fri Nov 16, 2018 3:53 pm
1. is the script executable?
2. do you have python3 installed?
#27
Post by Jerry3904 » Fri Nov 16, 2018 3:53 pm
I see why: you (I guess) moved the player to a subfolder and didn't change the script. Now works. I also added a line for wlan0 and slightly adjusted spacing.
Here is the changed code for NET and MUSIC:
${goto 12}+----${color3}Net${color}
${goto 15}|${goto 40}|
${goto 15}|${goto 38}+-- eth0${goto 125}${addr eth0}
${goto 15}|${goto 38}+-- wlan0${goto 125}${addr wlan0}
${goto 15}|${goto 38}+-- Up
${goto 15}|${goto 40}|${goto 60}+-- Speed${goto 125}${upspeedf wlan0}KiB
${goto 15}|${goto 40}|${goto 60}+-- Total${goto 125}${totalup wlan0}KiB
${goto 15}|${goto 38}+-- Down
${goto 15}|${goto 40} ${goto 60}+-- Speed${goto 125}${downspeedf wlan0}KiB
${goto 15}|${goto 40} ${goto 60}+-- Total${goto 125}${totaldown wlan0}KiB
${goto 15}|
${goto 12}+----${color3}Music (Clementine)${color}
${goto 15} ${goto 40}|
${if_match "${execi 10 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -i}"=="yes"}${goto 15} ${goto 38}+-- ${execpi 4 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -a -w 45}
${goto 15} ${goto 38}+-- ${execpi 4 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -m -w 43}
${goto 15} ${goto 38}+-- ${execpi 4 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -t -w 43}
${goto 15} ${goto 40} ${goto 60}+-- ${execpi 4 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -l -w 43}
${goto 15} ${goto 40} ${goto 60}+-- ${execpi 4 python3 $HOME/.conky/BBQ-Digital/mediaplayer.py clementine -e -w 43}
${else}${goto 15} ${goto 38}+-- Clementine Not Running\
${endif}
#28
Post by Jerry3904 » Fri Nov 16, 2018 4:21 pm
Here is the corrected music code for Bridoux
${font Arial:bold:size=10}${color white}MUSIC ${color2}${hr 2}
##Clementine using mediaplayer.py script; orig ${font Open Sans:size=9}
${if_match "${execi 10 python3 $HOME/.conky/MX-bridouz/mediaplayer.py clementine -i}"=="yes"}
${color3}${font Open Sans:size=9}${execpi 4 python3 $HOME/.conky/MX-bridouz/mediaplayer.py clementine -tamlr -w 45}
${if_match "${execi 4 python3 $HOME/.conky/MX-bridouz/mediaplayer.py clementine -p}"=="Unknown"}\
Progress: ${alignr}Unknown
${else}\
Progress:
${color2}${execibar 4 python3 $HOME/.conky/MX-bridouz/mediaplayer.py clementine -p}
${execi 20 python $HOME/.conky/MX-bridouz/mediaplayer.py clementine -c /tmp/cover.jpg}${image /tmp/cover.jpg -p 114,678 -s 70x70 -n}
I also added in the wlan0 address line, now looks like this:
male
#29
Post by male » Fri Nov 16, 2018 5:19 pm
and here's a simple code for deadbeef as ticker
yours must adapt it yourself :happy:
--deadbeef als Laufschrift
--male im Oktober 2017
conky.config = {
	use_xft = true,
	font = 'monofur:size=12',
	xftalpha = 0.8,
	update_interval = 1,
	own_window = true,
	own_window_type = 'normal',
	own_window_transparent = true,
	own_window_hints = 'undecorated,sticky,below,skip_taskbar,skip_pager',  --
--own_window_argb_visual = true,
--own_window_argb_value = 0,
	double_buffer = true,
	alignment = 'bottom_right',
	gap_x = 10,
	gap_y = 20,
	minimum_width = 360, minimum_height = 50,
	maximum_width = 360,
	draw_shades = false,
	draw_outline = false,
	draw_borders = false,
	no_buffers = true,
	cpu_avg_samples = 2,
	net_avg_samples = 2,
	override_utf8_locale = true,
	color0 = 'EAEAEA',
	color1 = 'CDC439',
conky.text = [[
${if_running deadbeef-gtkui}
${if_match "${execi 1 /usr/bin/deadbeef --nowplaying "%a - %t" 2>/dev/null | sed 's/\!//g'}" == "nothing"}\
${alignc}deadbeef: ${color1}plays nothing${color}\
${else}\
${voffset -15}${font monofur:pixelsize=18}\
${if_match "${execi 5 /usr/bin/deadbeef --nowplaying "%y" 2>/dev/null}" == ""}\
${scroll 50 2 ${execi 16 /usr/bin/deadbeef --nowplaying "%a - %t" 2>/dev/null}}\
${else} ${if_match "${execi 5 /usr/bin/deadbeef --nowplaying "%y" 2>/dev/null}" == "0"}\
${else} ${scroll 50 2 ${execi 16 /usr/bin/deadbeef --nowplaying "%a - %t (%y)" 2>/dev/null}}${endif}\
${endif}\
${font monofur:pixelsize=10:style:bold}\
${execi 1 /usr/bin/deadbeef --nowplaying "%e / %l" 2>/dev/null}${endif}${font}
${else}${alignc}deadbeef: ${color1}is not open\
${endif}
#30
Post by Jerry3904 » Fri Nov 16, 2018 5:23 pm
That looks like fun, thanks
Return to “Art Discussion”
