antiX-19-b1-full and tsplash tests needed.
Post by anticapitalista » Thu Jun 13, 2019 5:43 pm
Could those of you running live versions of antiX-19-b1-full please test out our tsplash option.
Simply, at live boot menu, change splash=v to splasht=f or splasht=s or splasht=va
Post your comments on the splash screen
Re: antiX-19-b1-full and tsplash tests needed.
Post by fehlix » Thu Jun 13, 2019 6:59 pm
works in VirtualBox booted from ISO
used splasht cheat code: splasht=va
impressions:
:puppy:
Post by dolphin_oracle » Thu Jun 13, 2019 7:51 pm
for me, splasht=va is the most compelling, with the cycling text saying what's going on. splasht=s and splasht=f look the same, with the progress bar but no cycling text.
lenovo ThinkPad T530 - MX-18.3
lenovo s21e - antiX-19 beta 2 (live-USB)
BitJam
Post by BitJam » Thu Jun 13, 2019 8:15 pm
The "s" and "f" options do the same thing. They enable fbcondecor (console backgrounds) near the end of the boot process. These would already be enabled if "splash=v" was also given.
Will I cry when it's all over?
When I die will I see Heaven?
JayM
Qualified MX Guide
Post by JayM » Fri Jun 14, 2019 2:44 am
I tested the 64-bit version on my old AMD desktop. I still have the issue of slim not starting at boot on the live USB. I tried the various splash options, no difference.
$ inxi -Frcz
  Host: mx Kernel: 4.9.176-antix.1-amd64-smp x86_64 bits: 64
  Desktop: IceWM 1.5.5+git20190610
  Distro: antiX-19.b1_x64-full Marielle Franco 12 June 2019
  Type: Desktop Mobo: ASRock model: A780GM-LE serial: <filter>
  BIOS: American Megatrends v: P1.50 date: 05/25/2010
  Topology: Dual Core model: AMD Athlon 64 X2 5000+ bits: 64 type: MCP
  L2 cache: 1024 KiB
  Speed: 2613 MHz min/max: N/A Core speeds (MHz): 1: 2613 2: 2613
  Device-1: AMD RS780 [Radeon HD 3200] driver: radeon v: kernel
  Display: x11 server: X.Org 1.20.4 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL:
  renderer: AMD RS780 (DRM 2.49.0 / 4.9.176-antix.1-amd64-smp LLVM 7.0.1)
  v: 3.3 Mesa 18.3.6
  Device-1: AMD SBx00 Azalia driver: snd_hda_intel
  Sound Server: ALSA v: k4.9.176-antix.1-amd64-smp
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  Local Storage: total: 1.38 TiB used: 4.67 GiB (0.3%)
  ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
  ID-3: /dev/sdc type: USB vendor: Toshiba model: TransMemory
  ID-1: / size: 455.45 GiB used: 3.57 GiB (0.8%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
  System Temperatures: cpu: 40.0 C mobo: N/A
  1: deb https://mirror.freedif.org/MXLinux/repo/antixbuster/ buster main nonfree
  1: deb http://ftp.hk.debian.org/debian/ buster-updates main contrib non-free
  1: deb http://ftp.hk.debian.org/debian/ buster main contrib non-free
  2: deb http://security.debian.org/ buster/updates main contrib non-free
  No active apt repos in: /etc/apt/sources.list.d/onion.list
  Processes: 144 Uptime: 13m Memory: 7.55 GiB used: 227.4 MiB (2.9%)
  Shell: bash inxi: 3.0.33
tester@mx:~
I went ahead and installed it to a spare hard drive, using automatic partitioning on the entire disk, no encryption. I forgot to time the installation, but it was FAST! Maybe five or six minutes total. This is on a machine with only USB2, installing to a spinner not an SSD. Nothing crashed, errored out or went wrong during the installation:
demo@mx:~
$ sudo minstall -E
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Installer version: 1.0.6
+++ void MInstall::startup() +++
"uname -m | grep -q i686"
Exit: 1 QProcess::ExitStatus(NormalExit)
"test -d /sys/firmware/efi"
uefi = false
"command -v xfconf-query >/dev/null && su $(logname) -c 'xfconf-query --channel thunar-volman --property /automount-drives/enabled'"
"command -v xfconf-query >/dev/null && su $(logname) -c 'xfconf-query --channel thunar-volman --property /automount-drives/enabled --set false'"
+++ void MInstall::setupkeyboardbutton() +++
"locale -a | grep -Ev '^(C|POSIX)\\.?' | grep -E 'utf8|UTF-8'"
Exit: 0 QProcess::ExitStatus(NormalExit)
"ls /home | grep -Ev '(lost\\+found|demo|snapshot)' | grep -q [a-zA-Z0-9]"
"test -d /live/linux/home/demo"
"dpkg -s samba | grep '^Status.*ok.*' | sed -e 's/.*ok //'"
+++ void MInstall::buildServiceList() +++
+++ void MInstall::updatePartitionWidgets() +++
"/sbin/partprobe"
"blkid -c /dev/null"
"fdisk -l -o DEVICE,TYPE |grep 'EFI System' |cut -d\\  -f1 | cut -d/ -f3"
"lsblk -brno TYPE,NAME,UUID,SIZE,PARTTYPE,FSTYPE,LABEL,MODEL | grep -E '^(disk|part)'"
"blkid /dev/ | grep -q PTTYPE=\\\"gpt\\\""
"grub-probe -d /dev/sda2 2>/dev/null | grep hfsplus"
Name Size Model FS | isDisk isGPT isBoot isESP isNative isSwap
"sda" 500107862016 "ST9500325AS" "" | true false false false false false
"sda1" 607125504 "" "ntfs" | false false false false false false
"sda2" 499498614784 "" "ntfs" | false false false false false false
"sdb" 1000204886016 "ST1000DM010-2EP102" "crypto_LUKS" | true false false false false false
"sdc" 15518924800 "TransMemory" "" | true false false false false false
"sdc1" 15464398848 "" "ext4" | false false true false true false
"sdc2" 52428800 "" "vfat" | false false false true false false
QXcbConnection: XCB error: 3 (BadWindow), sequence: 1025, resource id: 10486765, major code: 40 (TranslateCoords), minor code: 0
+++ bool MInstall::checkDisk() +++
"smartctl -H /dev/sda|grep -w FAILED"
"smartctl -A /dev/sda| grep -E \"^  5|^196|^197|^198\" | awk '{ if ( $10 != 0 ) { print $1,$2,$10} }'"
+++ void MInstall::cleanup(bool) +++
"umount -l /mnt/antiX/boot/efi"
Exit: 32 QProcess::ExitStatus(NormalExit)
"umount -l /mnt/antiX/proc"
"umount -l /mnt/antiX/sys"
"umount -l /mnt/antiX/dev/shm"
"umount -l /mnt/antiX/dev"
"umount -l /mnt/antiX/home"
"umount -lR /mnt/antiX"
+++ bool MInstall::makePartitions() +++
"swapoff /dev/sda1"
Exit: 255 QProcess::ExitStatus(NormalExit)
"umount /dev/sda1"
"swapoff /dev/sda2"
"umount /dev/sda2"
 ---- PARTITION FORMAT SCHEDULE ----
Root: "/dev/sda1" 474860
Home: "/dev/sda1" 0
Swap: "/dev/sda2" 2048
Boot: "" 0
ESP: "" 0
"/bin/dd if=/dev/zero of=/dev/sda bs=512 count=100"
"parted -s /dev/sda mklabel msdos"
"parted -s --align optimal /dev/sda mkpart primary ext4 1MiB 474861MiB"
"parted -s --align optimal /dev/sda mkpart primary 474861MiB 476909MiB"
"partprobe"
+++ bool MInstall::formatPartitions() +++
"/sbin/mkswap /dev/sda2 -L swapantiX"
+++ bool MInstall::makeLinuxPartition(const QString&, const QString&, bool, const QString&) +++
"mkfs.ext4 -F /dev/sda1 -L \"rootantiX19\""
"/sbin/tune2fs -c0 -C0 -i1m /dev/sda1"
+++ bool MInstall::mountPartition(QString, QString, QString) +++
"/bin/mount /dev/sda1 /mnt/antiX -o defaults,noatime"
+++ bool MInstall::installLinux(int) +++
+++ bool MInstall::copyLinux(int) +++
"/bin/cp -av /live/aufs/bin /live/aufs/boot /live/aufs/dev /live/aufs/etc /live/aufs/lib /live/aufs/lib64 /live/aufs/media /live/aufs/mnt /live/aufs/opt /live/aufs/root /live/aufs/sbin /live/aufs/selinux /live/aufs/usr /live/aufs/var /live/aufs/home /mnt/antiX"
"blkid -o value UUID -s UUID /dev/sda1"
"blkid -o value UUID -s UUID /dev/sda2"
"blkid -o value UUID -s UUID "
Exit: 2 QProcess::ExitStatus(NormalExit)
Create fstab entries for:
rootdev "/dev/sda1" "UUID=8a84370a-949f-423a-a725-714091d4b829"
homedev "/dev/sda1" "UUID=8a84370a-949f-423a-a725-714091d4b829"
swapdev "/dev/sda2" "UUID=efb9ee7c-eb6b-44e8-836f-4bd15ed0688c"
bootdev "" "UUID="
"blkid /dev/sda1 -o value -s TYPE"
"/sbin/make-fstab -O --install /mnt/antiX --mntpnt=/media"
"/usr/sbin/live-to-installed /mnt/antiX"
Desktop menu
"chroot /mnt/antiX desktop-menu --write-out-global"
"/bin/rm -rf /mnt/antiX/home/demo"
"/bin/rm -rf /mnt/antiX/media/sd*"
"/bin/rm -rf /mnt/antiX/media/hd*"
"guess-hwclock"
+++ void MInstall::setServices() +++
Service:  "cron"
"chroot /mnt/antiX update-rc.d cron enable"
Service:  "sudo"
"chroot /mnt/antiX update-rc.d sudo enable"
Service:  "cpufrequtils"
"chroot /mnt/antiX update-rc.d cpufrequtils enable"
Service:  "smartmontools"
"chroot /mnt/antiX update-rc.d smartmontools enable"
Service:  "acpi-support"
"chroot /mnt/antiX update-rc.d acpi-support enable"
Service:  "acpid"
"chroot /mnt/antiX update-rc.d acpid enable"
Service:  "dbus"
"chroot /mnt/antiX update-rc.d dbus enable"
Service:  "gpm"
"chroot /mnt/antiX update-rc.d gpm enable"
Service:  "saned"
"chroot /mnt/antiX update-rc.d saned enable"
Service:  "avahi-daemon"
"chroot /mnt/antiX update-rc.d avahi-daemon enable"
Service:  "irqbalance"
"chroot /mnt/antiX update-rc.d irqbalance enable"
Service:  "loadcpufreq"
"chroot /mnt/antiX update-rc.d loadcpufreq enable"
Service:  "rmnologin"
"chroot /mnt/antiX update-rc.d rmnologin enable"
Service:  "haveged"
"chroot /mnt/antiX update-rc.d haveged enable"
Service:  "ssh"
"chroot /mnt/antiX update-rc.d ssh enable"
Service:  "bluetooth"
"chroot /mnt/antiX update-rc.d bluetooth enable"
Service:  "rsync"
"chroot /mnt/antiX update-rc.d rsync enable"
Service:  "cups"
"chroot /mnt/antiX update-rc.d cups enable"
"lspci -d 80ee:beef  | grep -q ."
"mv -f /mnt/antiX/etc/rc5.d/S*virtualbox-guest-utils /mnt/antiX/etc/rc5.d/K01virtualbox-guest-utils >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc4.d/S*virtualbox-guest-utils /mnt/antiX/etc/rc4.d/K01virtualbox-guest-utils >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc3.d/S*virtualbox-guest-utils /mnt/antiX/etc/rc3.d/K01virtualbox-guest-utils >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc2.d/S*virtualbox-guest-utils /mnt/antiX/etc/rc2.d/K01virtualbox-guest-utils >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rcS.d/S*virtualbox-guest-x11 /mnt/antiX/etc/rcS.d/K21virtualbox-guest-x11 >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc5.d/S*smbd /mnt/antiX/etc/rc5.d/K01smbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc4.d/S*smbd /mnt/antiX/etc/rc4.d/K01smbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc3.d/S*smbd /mnt/antiX/etc/rc3.d/K01smbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc2.d/S*smbd /mnt/antiX/etc/rc2.d/K01smbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc5.d/S*samba-ad-dc /mnt/antiX/etc/rc5.d/K01samba-ad-dc >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc4.d/S*samba-ad-dc /mnt/antiX/etc/rc4.d/K01samba-ad-dc >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc3.d/S*samba-ad-dc /mnt/antiX/etc/rc3.d/K01samba-ad-dc >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc2.d/S*samba-ad-dc /mnt/antiX/etc/rc2.d/K01samba-ad-dc >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc5.d/S*nmbd /mnt/antiX/etc/rc5.d/K01nmbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc4.d/S*nmbd /mnt/antiX/etc/rc4.d/K01nmbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc3.d/S*nmbd /mnt/antiX/etc/rc3.d/K01nmbd >/dev/null 2>&1"
"mv -f /mnt/antiX/etc/rc2.d/S*nmbd /mnt/antiX/etc/rc2.d/K01nmbd >/dev/null 2>&1"
"sed -i 's/'\"$(grep 127.0.0.1 /etc/hosts | grep -v localhost | head -1 | awk '{print $2}')\"'/antix19b1-64/' /mnt/antiX/etc/hosts"
"echo \"antix19b1-64\" | cat > /mnt/antiX/etc/hostname"
"echo \"antix19b1-64\" | cat > /mnt/antiX/etc/mailname"
"sed -i 's/.*send host-name.*/send host-name \"antix19b1-64\";/g' /mnt/antiX/etc/dhcp/dhclient.conf"
"echo \"example.dom\" | cat > /mnt/antiX/etc/defaultdomain"
+++ void MInstall::setLocale() +++
Update locale
"chroot /mnt/antiX /usr/sbin/update-locale \"LANG=en_US.UTF-8\""
"ln -nfs /usr/share/zoneinfo/Asia/Manila /mnt/antiX/etc/localtime"
"ln -nfs /usr/share/zoneinfo/Asia/Manila /etc/localtime"
"echo Asia/Manila > /mnt/antiX/etc/timezone"
"echo Asia/Manila > /etc/timezone"
"cp -f /etc/default/rcS /mnt/antiX/etc/default"
"echo '0.0 0 0.0\n0\nLOCAL' > /etc/adjtime"
"hwclock --hctosys"
"cp -f /etc/adjtime /mnt/antiX/etc/"
"sed -i '/data0=/c\\data0=%l:%M' /home/demo/.config/xfce4/panel/xfce4-orageclock-plugin-1.rc"
"sed -i '/data0=/c\\data0=%l:%M' /mnt/antiX/etc/skel/.config/xfce4/panel/xfce4-orageclock-plugin-1.rc"
"sed -i 's/%H:%M/%l:%M/g' /mnt/antiX/etc/skel/.icewm/preferences"
"sed -i 's/%k:%M/%l:%M/g' /mnt/antiX/etc/skel/.fluxbox/init"
"sed -i 's/%k:%M/%l:%M/g' /mnt/antiX/etc/skel/.jwm/tray"
Localize repo
"chroot /mnt/antiX localize-repo default"
"chroot /mnt/antiX chpasswd"
"cp -a /mnt/antiX/etc/skel /mnt/antiX/home"
"mv -f /mnt/antiX/home/skel /mnt/antiX/home/tester"
"chown -R demo:demo /mnt/antiX/home/tester"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/group"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/gshadow"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/passwd"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/shadow"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/slim.conf"
"sed -i 's/demo/tester/g' /mnt/antiX/etc/lightdm/lightdm.conf"
"sed -i 's/demo/tester/g' /mnt/antiX/home/*/.gtkrc-2.0"
"sed -i 's/demo/tester/g' /mnt/antiX/root/.gtkrc-2.0"
"sed -i 's/#auto_login/auto_login/g' /mnt/antiX/etc/slim.conf"
"sed -i 's/#default_user /default_user /g' /mnt/antiX/etc/slim.conf"
"touch /mnt/antiX/var/mail/tester"
"/bin/sync"
+++ bool MInstall::installLoader() +++
"ls /mnt/antiX/boot | grep 'initrd.img-3.6'"
"blkid /dev/sda | grep -q PTTYPE=\\\"gpt\\\""
"parted -s /dev/sda set 1 boot on"
"mount -o bind /dev /mnt/antiX/dev"
"mount -o bind /sys /mnt/antiX/sys"
"mount -o bind /proc /mnt/antiX/proc"
Installing Grub
"grub-install --target=i386-pc --recheck --no-floppy --force --boot-directory=/mnt/antiX/boot /dev/sda"
"/live/bin/non-live-cmdline"
grubDefault is  "quiet"
intermediate ("vga=791", "gfxsave", "quiet", "quiet")
Add cmdline options to Grub ("vga=791", "gfxsave", "quiet")
cmdlinestring "vga=791 gfxsave quiet"
"sed -i -r 's|^(GRUB_CMDLINE_LINUX_DEFAULT=).*|\\1\"vga=791 gfxsave quiet\"|' /mnt/antiX/etc/default/grub"
Update Grub
"chroot /mnt/antiX update-grub"
Update initramfs
"chroot /mnt/antiX update-initramfs -u -t -k all"
clear chroot env
"umount /mnt/antiX/proc"
"umount /mnt/antiX/sys"
"umount /mnt/antiX/dev"
"mountpoint -q /mnt/antiX/boot/efi"
"sleep 1"
"command -v xfconf-query >/dev/null && su $(logname) -c 'xfconf-query --channel thunar-volman --property /automount-drives/enabled --set '"
"cp /var/log/minstall.log /mnt/antiX/var/log >/dev/null 2>&1"
"rm -rf /mnt/antiX/mnt/antiX >/dev/null 2>&1"
demo@mx:~
I had unselected the auto-reboot so I could copy the console text above to a file, then did a manual reboot via the menu and it hung at shutting down the power-saving features so I had to do a hard reboot (pulling out the power cord.)
When I rebooted into antiX 19b1 I no longer got the three-minute black screen of death: booting and logging in worked as expected. So whatever is wrong with antiX 19 vs. this PC, it's an issue only when booting the live USB installation medium.
I opened a terminal and did a sudo apt update (after running the repo manager and checking what repositories it had selected for me) and this is what I got:
$ sudo apt update
Get:1 http://ftp.hk.debian.org/debian buster-updates InRelease [46.8 kB]
Get:2 http://security.debian.org buster/updates InRelease [39.1 kB]
Get:3 http://ftp.hk.debian.org/debian buster InRelease [163 kB]
Ign:4 https://mirror.freedif.org/MXLinux/repo/antixbuster buster InRelease
Get:5 http://ftp.hk.debian.org/debian buster/main amd64 Packages [7,902 kB]
Err:6 https://mirror.freedif.org/MXLinux/repo/antixbuster buster Release
  404  Not Found [IP: 113.161.52.138 443]
Get:7 http://security.debian.org buster/updates/main amd64 Packages [1,132 B]
Get:8 http://security.debian.org buster/updates/main i386 Packages [1,132 B]
Get:9 http://security.debian.org buster/updates/main Translation-en [678 B]
Get:10 http://ftp.hk.debian.org/debian buster/main i386 Packages [7,861 kB]
Get:11 http://ftp.hk.debian.org/debian buster/main Translation-en [5,973 kB]
Get:12 http://ftp.hk.debian.org/debian buster/contrib i386 Packages [47.1 kB]
Get:13 http://ftp.hk.debian.org/debian buster/contrib amd64 Packages [51.2 kB]
Get:14 http://ftp.hk.debian.org/debian buster/contrib Translation-en [45.0 kB]
Get:15 http://ftp.hk.debian.org/debian buster/non-free amd64 Packages [88.0 kB]
Get:16 http://ftp.hk.debian.org/debian buster/non-free i386 Packages [76.3 kB]
Get:17 http://ftp.hk.debian.org/debian buster/non-free Translation-en [88.3 kB]
Reading package lists... Done
E: The repository 'https://mirror.freedif.org/MXLinux/repo/antixbuster buster Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
When I ping mirror.freedif.org it returns
$ ping mirror.freedif.org
PING home2.freedif.org (113.161.52.138) 56(84) bytes of data.
64 bytes from static.vnpt.vn (113.161.52.138): icmp_seq=1 ttl=49 time=107 ms
64 bytes from static.vnpt.vn (113.161.52.138): icmp_seq=2 ttl=49 time=108 ms
64 bytes from static.vnpt.vn (113.161.52.138): icmp_seq=3 ttl=49 time=106 ms
64 bytes from static.vnpt.vn (113.161.52.138): icmp_seq=4 ttl=49 time=106 ms
^C
--- home2.freedif.org ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3002ms
rtt min/avg/max/mdev = 106.291/107.059/108.068/0.786 ms
I'll put that hard drive back in and test some of the splash screen parameters tomorrow or Sunday, and also test the 32-bit version of b1 on my netbook.
Please read How To Ask For Help and How to Break Your System.
MX User Manual: hold down ALT and press F1. Further information may be found in the MX Wiki.
PPC
Post by PPC » Fri Jun 14, 2019 6:38 am
I just tested "splasht=f" on B1 32 bits on virtual box- the boot process looks way better for non techie users.
Everything looks simpler. One of these options should be the standard for antiX 19...
"splash=v" probably should be used only for debugging any problems. I know even when the system boots fine, there may be some precious information displayed in the "normal" boot sequence (for example- when it takes too long- it happened to me- antiX 17.X keeps looking for some file system I never used, for some 40 seconds, at boot time, then boots normaly) . But, if we are trying to "sell" antiX to Windows 7 refugees, for example, the first thing they see when they try the distro should not be a scary and seemingly incomprehensible string of "unneeded" information. If a newbie user tries to boot and, for example, gets dropped to the cli, probably nothing they see in the boot sequence will help them. They either give up on the distro or come to the forum, were someone advises to try another splash sequence and take a picture of the info or writing it down and post it all in the forum...
Another "small" but much needed face lift in my favorite OS...
P.
oops
Post by oops » Fri Jun 14, 2019 7:03 am
That's work here: antiX-19.b1_386-full, with splasht=f , on virtualbox
inxi: 3.0.33
demo@antix1:~
$ cat /proc/cmdline
vga=791 lang=fr_FR quiet splasht=f disable=lx
demo@antix1:~
$ inxi -v8
  Host: antix1 Kernel: 4.9.176-antix.1-486-smp i686 bits: 32 compiler: gcc
  v: 8.3.0 Desktop: IceWM 1.5.5+git20190610 dm: SLiM 1.3.6
  Distro: antiX-19.b1_386-full Marielle Franco 12 June 2019
  base: Debian GNU/Linux 10 (buster)
  Type: Virtualbox System: innotek product: VirtualBox v: 1.2
  serial: <root required> Chassis: Oracle Corporation type: 1
  Mobo: Oracle model: VirtualBox v: 1.2 serial: <root required>
  BIOS: innotek v: VirtualBox date: 12/01/2006
Memory:
  RAM: total: 2.82 GiB used: 110.7 MiB (3.8%)
Head_on_a_Stick
Post by Head_on_a_Stick » Fri Jun 14, 2019 1:41 pm
The options work for me under QEMU/KVM but the screen flashes on & off while it is loading.
There's no flashing if tested on the bare metal (but my E485 isn't supported by the kernel so I can't load the desktop).
I prefer the va option, the shortcuts to return to standard booting are useful.
"Direct action is the logical, consistent method of anarchism." — Emma Goldman
JayM
Qualified MX Guide
Post by JayM » Sat Jun 15, 2019 4:40 am
Just tested 32-bit version briefly on my netbook:
$ inxi -Fxrz
  Type: Other-vm? System: AVERATEC product: N1130 v: N/A serial: <filter>
  Mobo: AVERATEC model: N1130 serial: <filter> BIOS: Phoenix
  v: NAPA0001.86C.0056.D.0907311757 date: 07/31/09
  ID-1: BAT0 charge: 0 Wh condition: 65.3/65.3 Wh (100%)
  model: AVERATEC N1130 status: Unknown
  Topology: Single Core model: Intel Atom N270 bits: 32 type: MT
  arch: Bonnell rev: 2 L2 cache: 512 KiB
  flags: nx pae sse sse2 sse3 ssse3 bogomips: 6384
  Speed: 800 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 800 2: 800
  Device-1: Intel Mobile 945GSE Express Integrated Graphics driver: i915
  v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.4 driver: intel
  unloaded: fbdev,modesetting,vesa resolution: 1024x600~60Hz
  OpenGL: renderer: Mesa DRI Intel 945GME x86/MMX/SSE2 v: 1.4 Mesa 18.3.6
  Device-1: Intel NM10/ICH7 Family High Definition Audio
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.9.176-antix.1-486-smp
  Device-1: Ralink RT3090 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
  v: 2.3.0 port: 18e0 bus ID: 02:00.0
  Device-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet
  driver: r8169 v: 2.3LK-NAPI port: 2000 bus ID: 04:00.0
  Local Storage: total: 119.29 GiB used: 1.12 GiB (0.9%)
  ID-1: /dev/sda vendor: Gigabyte model: GP-GSTFS31120GNTD size: 111.79 GiB
  ID-2: /dev/sdb type: USB vendor: Generic model: Flash Disk size: 7.50 GiB
  ID-1: / size: 1.55 GiB used: 2.1 MiB (0.1%) fs: overlay source: ERR-102
  System Temperatures: cpu: 26.8 C mobo: 26.8 C
  1: deb http://repo.antixlinux.com/buster buster main nonfree
  1: deb http://ftp.us.debian.org/debian/ buster-updates main contrib non-free
  1: deb http://ftp.us.debian.org/debian/ buster main contrib non-free
  Processes: 127 Uptime: 15m Memory: 1.96 GiB used: 316.3 MiB (15.8%)
  Init: SysVinit runlevel: 5 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3
  inxi: 3.0.33
demo@antix1:~
splasht=f and splasht=s look identical. I prefer splasht=va as it shows a bit of the boot progress at a high level, so the user can see that something's happening but without the usual big bunch of boot process messages.
Installation (automatic, entire disk, no encryption) took 5 minutes 9 seconds.
$ sudo minstall -E
grep: /sys/firmware/efi/fw_platform_size: No such file or directory
"grep -q 64 /sys/firmware/efi/fw_platform_size"
uefi = false
"/sbin/partprobe"
"sda" 120034123776 "GIGABYTE_GP-GSTFS31120GNTD" "" | true false false false false false
"sda1" 535822336 "" "ext4" | false false false false true false
"sda2" 117315731456 "" "crypto_LUKS" | false false false false true false
"sda3" 2147483648 "" "crypto_LUKS" | false false false false true false
"sdb" 8053063680 "Flash_Disk" "" | true false false false false false
"sdb1" 7998537728 "" "ext4" | false false true false true false
"sdb2" 52428800 "" "vfat" | false false false true false false
QXcbConnection: XCB error: 3 (BadWindow), sequence: 1071, resource id: 10488496, major code: 40 (TranslateCoords), minor code: 0
"swapoff /dev/sda1"
"umount /dev/sda1"
"swapoff /dev/sda2"
"umount /dev/sda2"
"swapoff /dev/sda3"
"umount /dev/sda3"
Root: "/dev/sda1" 112393
Home: "/dev/sda1" 0
Boot: "" 0
ESP: "" 0
"parted -s --align optimal /dev/sda mkpart primary ext4 1MiB 112394MiB"
"parted -s --align optimal /dev/sda mkpart primary 112394MiB 114442MiB"
"partprobe"
rootdev "/dev/sda1" "UUID=59ed0467-e0cd-4e32-b556-cfb9b9389861"
homedev "/dev/sda1" "UUID=59ed0467-e0cd-4e32-b556-cfb9b9389861"
swapdev "/dev/sda2" "UUID=2ccc80ef-ef57-43a2-aa8e-7a48331088aa"
bootdev "" "UUID="
Desktop menu
"guess-hwclock"
Service:  "cron"
Service:  "sudo"
Service:  "acpid"
Service:  "dbus"
Service:  "gpm"
Service:  "saned"
Service:  "haveged"
Service:  "ssh"
Service:  "rsync"
Service:  "cups"
"sed -i 's/'\"$(grep 127.0.0.1 /etc/hosts | grep -v localhost | head -1 | awk '{print $2}')\"'/antix1/' /mnt/antiX/etc/hosts"
"echo \"antix1\" | cat > /mnt/antiX/etc/hostname"
"echo \"antix1\" | cat > /mnt/antiX/etc/mailname"
"sed -i 's/.*send host-name.*/send host-name \"antix1\";/g' /mnt/antiX/etc/dhcp/dhclient.conf"
Update locale
"hwclock --hctosys"
Localize repo
"/bin/sync"
Installing Grub
intermediate ("vga=791", "quiet", "quiet")
Add cmdline options to Grub ("vga=791", "quiet")
cmdlinestring "vga=791 quiet"
"sed -i -r 's|^(GRUB_CMDLINE_LINUX_DEFAULT=).*|\\1\"vga=791 quiet\"|' /mnt/antiX/etc/default/grub"
Update Grub
Update initramfs
clear chroot env
"sleep 1"
demo@antix1:~
I found conman very easy to use to connect using my wifi: disable wired, enable wifi, click on my router's SSID, enter the password. Definite improvement over wicd and a lot easier to use. antiX19b1 seems to run faster than antiX 17.4 on the same machine.
Further testing in the next few days including the assembly-line installation.
JayM
Qualified MX Guide
#10
Post by JayM » Sun Jun 16, 2019 1:28 am
Testing the 32-bit version as a regular user, just doing things on the computer. My observations after using the beta for an hour or two:
I enabled Preferences/Task Bar/TaskBarShowNetStatus then logged out and back in. Nothing changed on the task bar. There's no wifi status icon, just Menu, Show Desktop, workspace switcher, speaker icon, battery indicator and the clock. This is using the stock desktop. I have verified that TaskBarShowNetStatus is enabled/selected (there's the small black diamond next to it.) It just doesn't seem to work. Just for fun I disabled TaskBarShowClock then right-clicked on the taskbar and selected Refresh, and the clock was still there. Maybe I just don't understand how this taskbar works?
The date and time were incorrect. I confirmed that the settings were correct, rebooted and fund them wrong in my BIOS. This may not have anything to do with antiX, it may be just this computer. FYI it doesn't retain BIOS settings if I unplug the AC power supply so I always leave it plugged in.
In Firefox, Preferences/Search/Find More Search Engines goes to startpage.com's main search page. Expected behavior is to be taken to https://addons.mozilla.org/en-US/firefox/search-tools/ where additional search engines for FF can be installed, including StartPage.
I ran the speaker test and have no sound. Again, may not be an antiX issue, the internal speakers in this piece of junk may have stopped working. I will try to verify later by booting another distro's live USB then edit this post with the results.
I saved my text document containing the above notes to my desktop but that document's icon doesn't appear on the desktop even after logging out and in. (Also the taskbar's clock is still there, and there's no network icon.) The only desktop icons are Files and help.
Return to “antiX”
